Teraflex 4"in lift - Need confirmation
Old Apr 7, 2009 | 10:31 AM
Dal Bone's Avatar
Default Teraflex 4"in lift - Need confirmation
So I noticed that my front passenger sway bar link was knocking against my coil.
The 4inch lift kit came with 2 different sway bar links. One is about 2 inches longer than the other.
Does the longer sway bar links go on the front or the back?? I need to figure this out before I go to Moab tomorrow.
Old Apr 7, 2009 | 10:40 AM
Offroadme's Avatar
it does not tell you in the instructions ?? i know they had an updated sway bar link what do they look like have any pics ??
Old Apr 7, 2009 | 11:05 AM
ranwitscissorz's Avatar
Longer always in the back
Old Apr 7, 2009 | 12:03 PM
asjackman's Avatar
i was going to say, the shorter up front.
Old Apr 7, 2009 | 12:14 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Shorter link in the front.
Old Apr 7, 2009 | 12:23 PM
Mine was longer in the back. Shorter disconnects are up front.
Old Apr 7, 2009 | 12:29 PM
Dal Bone's Avatar
Thats what I had originally when I installed the lift. I took it over to TeraflexPlus and showed the service guy where my sway bar link was hitting my coil. He told me that the longer link goes on the front and this would fix the problem. I switched links and same problem....
Old Apr 7, 2009 | 03:21 PM
spylife's Avatar
Default sway links
when I did my 2.5" lift, the 2 sway links were for the rear, then you move the rear up to the front (they're a bit longer)
Old Apr 10, 2009 | 12:28 PM
Take a picture.
Old Apr 10, 2009 | 12:37 PM
JKRockStomper's Avatar
your fronts should look like this. Make sure you are outside to inside.
