Teraflex 4" long arms upgrade
Old Jul 1, 2012 | 12:26 PM
Orko's Avatar
Default Teraflex 4" long arms upgrade
Hi,
I currently have a 4" TF flex arms lift kit, I am debating how and if upgrading to the long arms will be beneficial. I have 2010 Rubicon with 35" MT tires.
Also, right now it is a little harsh ride , will the long arms help or I should consider changing to the EVO plush springs?
Thank you for your inputs
Old Jul 1, 2012 | 12:29 PM
Crazecodyk's Avatar
The roughness of the ride i think had more to do with the shock valving than the arms. It's said that long arms will give you a better road ride. It depends on what you want i guess. I'd say try to find a different shock first. Then if you still want ling arms get um...once you cut the factory brackets off there's no going back
Old Jul 1, 2012 | 07:33 PM
jesse0376's Avatar
I just installed evo plush springs and my tf 2.5" springs were alot softer :(
Old Jul 1, 2012 | 10:46 PM
socaldozer's Avatar
The reason they felt softer is your control arms are at a more severe angle with the 4" springs making the bumps feel rough. If you went long arm your ride would improve dramatically at a 4" lift height
Old Jul 2, 2012 | 02:08 AM
Orko's Avatar
Will improve with or without the evo springs?
Old Jul 2, 2012 | 09:01 AM
socaldozer's Avatar
The long arm kit will improve your ride as far as the Evo springs. Everyone I have talked to with them says they are a really nice ride. But almost all of those guys ran long arms.
Old Jul 2, 2012 | 09:19 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
what shocks are you running with our plush ride coils?
Old Jul 2, 2012 | 05:16 PM
Orko's Avatar
Question for Chris: do you really need a 1"spacer with the evo springs in order to keep the lift height? Will this limit the "plush" of the springs and it's all purpose?
