Teraflex 6" what caster
With a Teraflex 6" assuming unmodified stock axles, and no extra suspension lift, what caster are you at and are you happy with it? (Or what angle is your pinion at). I am just curious to compare yours with mine?
FRONT AXLE
Left Caster 1.4 deg
Right Caster 1.7 deg
Left Camber –0.7 deg
Right Camber –0.5 deg
Left Toe 1/16”
Right Toe 1/16”
REAR AXLE
Left Camber –0.4 deg
Left Toe 1/16”
Right Toe 1/32”
My steering is pretty twitchy especially when going uphill when there is not so much weight on the front tire. I am going to incrase my front caster from 1.4 deg to a bit over 3 and see how it goes.
FRONT AXLE
Left Caster 1.4 deg
Left Toe 1/16”
Right Toe 1/16”
REAR AXLE
Left Toe 1/16”
Right Toe 1/32”
