TeraFlex BB 2.5 Spring full flex (pic)
Old Jan 15, 2010 | 11:29 AM
frankie945's Avatar
Default TeraFlex BB 2.5 Spring full flex (pic)
Figured I would put the JK under full flex today. I should have went with 3" springs. This is flexed to the bump stop. I figured I would have made it past the pole. Need to take a 1" off my bump stops or something. I flexed the rear and got higher up about 3 " past the pole.
[IMG][/IMG]
Old Jan 15, 2010 | 12:21 PM
nthinuf's Avatar
Are you going to flats? Or at least prepared to chop the flares up? Pulling out some bumpstop will have the tires rubbing...
Old Jan 15, 2010 | 12:53 PM
frankie945's Avatar
Plan on Bushwacker Flats this spring. I should have snaped a pic from the side and when I flexed the rear it was impressive. Added that 1" spacer made a big difference. Still had decent amount of clearance left. Also plan on a MORE 1" body lift this spring.
Old Jan 15, 2010 | 01:19 PM
Heavy Metal's Avatar
Here's some before and after shots of flex on the same gravel pile.
Old Jan 15, 2010 | 01:58 PM
frankie945's Avatar
^^^ That is a stock set up though right?? Looks like it.
Does Teraflex make shorter bump stops I guess?? I would like to have a little more flex. Because I will have plenty of room here real soon. And would like to take care of this first. My front brake lines still had plenty of play.
