Teraflex BB question
Old May 5, 2014 | 05:04 PM
randym44's Avatar
Default Teraflex BB question
I'm looking at the Teraflex 2.5" BB and not sure what the difference is between the "no shock" products - one being with adapters and the other without adapters. Can someone help out?
Old May 5, 2014 | 05:08 PM
nthinuf's Avatar
You generally want your shocks to be long enough to compensate for the added lift height. So you can buy a kit that includes shocks, buy a kit with adapters that will 'lengthen' your current shocks, or you buy a kit without and supply your own shocks that are long enough for that lift height.
Old May 5, 2014 | 05:13 PM
lvallejox's Avatar
With shocks: comes with 4 shocks.
Without shocks: comes with adapters that install on the stock shocks to extend them for when you add the spacers to the springs.
Old May 5, 2014 | 07:34 PM
randym44's Avatar
Gotcha. So installing BB using factory Rubicon shocks buy the kit with the adapters. Thanks.
Old May 5, 2014 | 07:41 PM
nthinuf's Avatar
Yep, if you like your current shocks there is nothing wrong with running adapters. Then in the future, you can move to a longer shock if you decide to.
