Teraflex Big Brake Kit
Old Sep 1, 2013 | 04:36 PM
winkelhawk's Avatar
Default Teraflex Big Brake Kit
I finally got some time to do a few more projects on the Jeep. I install the Teraflex big brake kit and Crown brake lines on the JK today. The pedal is soft but what a difference in stopping it made. I think I am going to grab the master cylinder to firm up the pedal. Install went fairly smooth except for 1 broken anti-squeak clip. Quick run to Pepboys and was able to finish it up. I am going to try bleeding the brakes first before ordering the master cylinder. Anyone successful using the 2010 master cylinder? I was hoping to save some money not replacing it.
ID:	493964Click image for larger version
ID:	493965Click image for larger version
ID:	493966Click image for larger version
ID:	493967Click image for larger version
Old Sep 1, 2013 | 05:06 PM
HappyJK's Avatar
Bleed it good and see if it firms up. If it was good before, it should be good now.
Old Sep 1, 2013 | 05:15 PM
shabbernigdo's Avatar
from all the sources ive read. unless you get the biggher TF master cylinder you will always have the soft pedal. the bigger caliper and bigger surface areas of the pistons requires the master cylinder to move more fluid that the stock one dosent have the capacity to do like the TF one does.
Old Sep 1, 2013 | 05:24 PM
jeeeep's Avatar
the 2010 should be fine and is preferred - I almost bought this and did stop at TF shop to talk with them.
What order are you bleeding your brakes in? are you doing the fronts only or did you open the rears to bleed them as well?
if you tried to bleed all 4 brakes, start with the passenger side rear brake. If you just worked on your front brake lines, then you need to start at your passenger side front brake.
The idea is that you just need to start from the brake that is farthest from the master cylinder.
don't let your master get too low on fluid - keep it full between bleeds
Old Sep 2, 2013 | 02:00 AM
winkelhawk's Avatar
Thanks for the advice. I did bleed all 4 wheel starting from the passenger rear. I'll bleed them again today and hopefully it will firm up. Northridge recommended the TF master cylinder even though I have a 2010.
Old Sep 2, 2013 | 02:35 AM
HLKSTER's Avatar
Do the TF master brake cylinder I did and it made a big difference...
Old Sep 2, 2013 | 06:39 AM
ChesterJFK's Avatar
Is the 2010 MC better than say a 2011-2013 MC??
Old Sep 2, 2013 | 10:54 AM
winkelhawk's Avatar
For some reason TF says you don't need the MC if you have a 2010. Not sure why that is. I am assuming it has a bigger bore than the other years.
Old Sep 2, 2013 | 12:01 PM
LoneWolf's Avatar
Has anyone had this kit long enough to need to replace the pads? I'm curious if a set of standard JK pads would fit or if I'd always be dependent on TF if I were to install this kit.
Also, has anyone heard of them offering a kit for the rears, too? Seems odd to only offer the fronts.
Old Sep 2, 2013 | 12:41 PM
winkelhawk's Avatar
2010 Ram 1500 pads will fit.
