Teraflex Budget Boost
Old Mar 16, 2010 | 04:18 PM
bbhockey19's Avatar
Default Teraflex Budget Boost
What is the Difference between these 2 Teraflex Budget boosts.
http://www.northridge4x4.com/proddet...rod=TF-1355200
Or
http://www.northridge4x4.com/proddet...rod=TF-1255200
They look exactly the same, both with Shock adapters.
Old Mar 16, 2010 | 04:55 PM
Rub61's Avatar
1355200 no shocks 1255200 shocks
Old Mar 16, 2010 | 05:03 PM
racin444's Avatar
x2 on that, the first one uses shock adapters for your stock shocks and the second one has teraflex shocks. Same lift.
Old Mar 16, 2010 | 06:10 PM
CrazyShadow's Avatar
hmm.as I can understand, fist one = no shock,no adapter
second = with adapter or with the option longer shock no adapter(+145$)
Old Mar 16, 2010 | 06:48 PM
bbhockey19's Avatar
Hmmm.. Alot of Different answers, May have to call up Dave at Northridge!
Old Mar 16, 2010 | 07:03 PM
Stuka's Avatar
1255200 has shocks. The other does not. This is the only difference.
Old Mar 16, 2010 | 08:48 PM
randyd's Avatar
I went with the 2.5 BB Changed to the 2.5 coil lift right after that... Go with the coil lift!!!!
Old Mar 26, 2010 | 05:13 PM
racin444's Avatar
woops my eyes are deceiving me!
Thought I saw the shock adapters seeing as i bought my 2.5 teraflex BB with adapters from NORTHRIDGE4X4
Old Mar 26, 2010 | 07:48 PM
Easyryder01's Avatar
no shocks on first one, so you get extensions. Shocks on the second one, no extensions. I have the first kit, very simple to install, and use the insrtuctions here on the forum not in the box. The pictures and the help here is unbeatable. Good luck.
Old Mar 26, 2010 | 08:01 PM
JFDATLAW's Avatar
What is the rationale behind getting shocks or just using the adapters? For minimal off roading, does it matter? I'm thinking if I save a few bucks on shocks then that is just more money for something else.
