Teraflex Budget Boost
Old Nov 23, 2010 | 02:56 PM
Super Stroked's Avatar
Default Teraflex Budget Boost
I need some help from y'all. Looking to level out my 08 JK Rubicon. Looking at the teraflex budget boost, but even it has three options. I'm torn between which one to get. Looking to see if any of you guys or even teraflex themselves can point me in the right direction. Jeep will eventually be on 35's but for now gonna rock the stock bfg's till they are gone. Tired of looking at a sagging front end. Pics would be great too. I've searched a lot of threads about them, just looking for opinions on which version of the kit to get.
Thanks in advance.
Old Nov 23, 2010 | 03:24 PM
Cpt. Flapjack's Avatar
the Teraflex 2.5" budget boost won't level the jeep. it uses the same size pucks all the way around. You either need a leveling kit or new springs. I had the 2.5 with shock extentions for a year and it wheeled great. My springs sat level without the lift, so it stayed level with it.
Old Nov 23, 2010 | 03:35 PM
I was thinking it used the same size pucks, but wasn't sure if the front's where a little bigger or not. Wish mine sat level, the front is definitely lower than the rear.
Old Nov 23, 2010 | 03:36 PM
Robar's Avatar
Have you looked at these?
http://www.northridge4x4.com/proddet...rod=TF-1155200
http://www.northridge4x4.com/proddet...?prod=CE-9802F
http://www.northridge4x4.com/proddet...rod=TF-1351500
Old Nov 23, 2010 | 03:46 PM
Loadbreak's Avatar
You may want to talk to Joe at Teraflex. I think they changed the rear puck from 2.5 to 2 inches??
Old Nov 23, 2010 | 05:02 PM
That would be great if they did. Guess i'm gonna be making a phone call
Old Nov 23, 2010 | 05:09 PM
coltc2000's Avatar
Just order the coil leveling kit 2'' front 1'' rear 35s fit without a problem and look as if they belonged.
Old Nov 23, 2010 | 05:50 PM
kking08's Avatar
here is a teraflex 2.5 lift with springs, using the stock shocks, tires are 35s
[IMG][/IMG]
Old Nov 23, 2010 | 08:19 PM
Dozerdriver's Avatar
I have the newer kit and the front is 2.5 and the rear is 2" but I still have a rake...
Old Nov 23, 2010 | 08:24 PM
chipmaker's Avatar
Since you have the Rubicon, get the coil kit w/ the extensions and be done w/ it. Perfect height, level, rides great etc...
Call Dan @ ORW!
