Teraflex Control arm clicking noise
Old Sep 19, 2009 | 06:26 PM
09BlackRubiNC's Avatar
Default Teraflex Control arm clicking noise
I am running the Teraflex control arms with a teraflex 3" lift. I have a clicking noise anytime the suspension is moving. I actually think it may be a squeaking noise coming from the rear lower CA bushing. I've double checked that all bolts are tightened.
Old Sep 19, 2009 | 06:33 PM
mkjeep's Avatar
Are you sure your springs aren't hitting anything?
Old Sep 19, 2009 | 06:43 PM
blazer4949's Avatar
My rear clicking with the TF 3" Full Flex kit was the bolt on the adjustable trackbar hitting the
spring.
Solution: Shorten rear control arms to pull the whole rear axle forward by about an inch or more.
Old Sep 20, 2009 | 04:27 AM
spring.
Mine doesn't appear to be doing that. Mine can click or squeak.... sounds more like a click to me, just from getting into the vehicle.
I only say a squeak because if I get under the vehicle and have someone rock it it appears to be the ungreased bushing on the lower control arm.
I should add, it isn't bothering me that it is there, as long as I can assure myself it is safe. I rode a Samurai before this Jeep with a Lock-Rite locker in the rear, so the clicking is not annoying me.
Old Sep 20, 2009 | 06:05 AM
Piginajeep's Avatar
Have you retorqued your suspension lately? It could be just a loose bolt
Old Sep 20, 2009 | 06:43 AM
Twice. The first time I found 1 loose bolt.
Old Sep 20, 2009 | 07:41 AM
mkjeep's Avatar
Are all the bolts torquing correctly? I had to replace a couple ctrl arm bolts cause they wouldn't torque. They would just keep turning, one just snapped off after doing this. I think after being torqued so much they get stretched and weaken. Get some grade 8's if this is the case. Mine was clicking until I did this. Also check your bushings, take the bolt all the way out to check though.
Old Sep 20, 2009 | 08:01 AM
wayoflife's Avatar
JK-Forum Founder
is there a chance that you installed your rear sway bar links on the inside of the axle mounts? if so, they are probably tapping on the backs of the lower control arm mounts.
Old Sep 20, 2009 | 08:58 AM
I did. I read about both methods and chose to go per the Teraflexx instructions.... however while looking at it per your post I did find the problem. On the passenger rear lower CA at the frame mount -the factory nut that holds itself in place as you tighten the bolt was scrubbing on the control arm. I bent it a little bit and now no noise! That isn't a problem on the driver side as the nut flips in the opposite direction.
Thanks for the input guys!
Old Sep 20, 2009 | 09:02 AM
wayoflife's Avatar
JK-Forum Founder
yup, very common problem and glad that's all it was
