Teraflex diff cover question
Old Sep 17, 2011 | 08:02 AM
jksooner's Avatar
Default Teraflex diff cover question
I just replaced my rear diff cover with a Teraflex. There is a portion on the top left side that looks as if it were cut too close in when manufactured, as you can see in the attached pics. you can see the lube locker sticking out a bit, and the edge of the bolt head hanging over the edge of the diff cover. Will this cause any problems? or will it will be ok? Obviously, I don't want to go back and replace the cover again, and pay for more gear oil, etc. if there won't be a problem, but I definitely will if needed. Maybe the Teraflex Sponsor can answer for me?
Thanks!
ID:	211972Click image for larger version
ID:	211973Click image for larger version
ID:	211974Click image for larger version
Old Sep 17, 2011 | 08:07 AM
Robar's Avatar
I wouldn't worry about it unless it leaks. There should be plenty of lip on the cover to seal the diff.
Old Sep 17, 2011 | 08:10 AM
jksooner's Avatar
Cool thanks... no leaks thus far.
