Teraflex front upper control arms dialing in caster
Old Dec 23, 2011 | 04:42 PM
Dieselguy's Avatar
Default Teraflex front upper control arms dialing in caster
Hey Guys, Im doing final adjustments of my alignment after installing all 8 flex arms from teraflex. I've over extended my welcome at the local dealership getting the free alignment checks in the process and have a question. Have any of you done before and after measurements of front upper control arms to determine how much change one turn of the helm joint makes? From all I can tell, one turn equates to .4 degrees of caster, but wondered if any of you have input.
Thanks
Old Dec 25, 2011 | 09:17 AM
Dieselguy's Avatar
Default .
Bump, any thoughts?
Old Dec 25, 2011 | 11:09 AM
BOLTRipper's Avatar
I know you can find a $5 angle finder at Harbor freight or Sears that will measure your caster angle. I think you need to know your number and not just guess, but thats just me...
In any case, if you don't want to actually find what you are running, I would make sure you are running each side equally and adjust for the most caster you can run without driveline vibrations.
BR-
Old Dec 25, 2011 | 11:11 AM
BOLTRipper's Avatar
Forgot to mention - Run the uppers all the way in and adjust your lowers to obtain your caster angle.
Old Dec 25, 2011 | 11:23 AM
Dieselguy's Avatar
Default .
Thanks for the response
I do know where Im at now, I am at 5.7 driver, 5.8 passenger. I am also running a Coast driveshaft with no vibes at this position. I just wanted to dial it closer to 5.2 or so to limit the angle a bit.
