Teraflex GUSSETS!!!
Old Nov 20, 2009 | 05:21 PM
joneszj's Avatar
Default Teraflex GUSSETS!!!
OK, so I'm not sure if anyone saw these yet, but Teraflex has a new product out it seems. Gussets!!!
Now a question. Will these work inside the EVO C2 gussets? And for the $35 posted on the site, is that just upper gussets, or will lowers be included as well? These look great.
Old Nov 20, 2009 | 05:28 PM
NTXJK's Avatar
Man im digging these
Old Nov 20, 2009 | 05:36 PM
backwoodjk's Avatar
They look solid, but I do not think these will work with the Evo's. I am not sure you would gain anything by trying to adding these to the C2's.
Old Nov 20, 2009 | 05:43 PM
mikesjk's Avatar
Yes they work with a little trimming. You have to make a little notch on the bottom of the top gusset.
Old Nov 20, 2009 | 07:54 PM
nangulator's Avatar
I will stick with my EVO c-gussets.
Old Nov 20, 2009 | 07:58 PM
mkjeep's Avatar
I fail to see the need to add these on top of the evo gussets, do one or the other and you should be fine.
Old Nov 20, 2009 | 08:54 PM
BlackNorthernJK's Avatar
Oh wow, those do look good...nice find, I'm gonna get them right now
Old Nov 20, 2009 | 09:00 PM
Stuka's Avatar
These are not meant to be used with the C2's. They are meant to be used on their own. And from what I can tell, they would work just as good. Possible better for the top. However, there is no support for the bottom. Although the bottom is not prone to bending like the top.
Old Nov 20, 2009 | 09:40 PM
nangulator's Avatar
I would like 2 know what you base this theory onI have not seen anything that works better than the EVO c2 gussets yet, I personally welded mine on. I am an ASE certified Master tech with about 20 years experience and alot of custom fabrication and engine building work under my "belt". I dont know what you do for a living, but maybe you should stick to that.
Old Nov 21, 2009 | 12:11 AM
toymaster's Avatar
Harshly said but I have to agree. This design is substantially weaker than the C2 design. Better than nothing by far but speaking from an engineering stand point weaker.
