Teraflex Knuckle Gusset Question
Old Apr 12, 2016 | 09:50 AM
Potato Potato's Avatar
Default Teraflex Knuckle Gusset Question
I am installing Teraflex knuckle gussets this weekend. For those of you that have installed these gussets, was it necessary to remove the coil springs?
I am running 2.5in TF coils.
Old Apr 12, 2016 | 03:36 PM
Hoopskier's Avatar
I put a set of those in before. I did not remove the springs. Some areas were tight to get into but still able to. I should add, I did not removed the ball joints either, just keep moved around and let the area cool when working closer to the ball joint area.
Old Apr 12, 2016 | 03:52 PM
I appreciate your input, thanks. I am replacing the ball joints so no worries there. I mainly don't want to have to loosen all the control arms, pull the springs, and re-torque everything if I don't have to. I remember hating that process when I did the lift.
Old Apr 12, 2016 | 08:01 PM
Chuck-The-Ripper's Avatar
Should've went with the G2 axle and gear. Like $10 more and they're a lot more support and you get uppers/lowers/ control arm skids.
Old Apr 13, 2016 | 04:32 PM
Originally Posted by Chuck-The-Ripper
Should've went with the alloy USA. Like $10 more and they're a lot more support and you get uppers/lowers/ control arm skids.
Seemed like my post was pretty straight forward and this doesn't help at all.
Old Apr 13, 2016 | 05:01 PM
You're right, but you're not the only one on this forum. Others will see this thread. If they see my post, they may discover a better option.
To answer your question, no, but it'll make it easier and only takes a minute.
Old Apr 14, 2016 | 03:31 AM
I get that, but I don't even see gussets listed on Alloy's website.
Old Apr 14, 2016 | 07:00 AM
That's because they don't sell them...
I meant G2 axle and gear gussets.
I apologize, I'm dumb lol.
Old Apr 14, 2016 | 07:15 AM
Dang, that is a nice kit for the price.
Old Apr 14, 2016 | 10:22 AM
kjeeper10's Avatar
Vet Army
That is a nice kit. Looks similar to Artec's. Actually the truss pieces together the same. Cheaper as a whole package too.. Nice find.
