teraflex leveler HELP!---doing work right now
Old Sep 4, 2011 | 06:25 AM
2saharas's Avatar
Default teraflex leveler HELP!---doing work right now
ok, If i just use 1 spacer in the front, do i use the factory sway bar links or the teraflex links that are 3 inches longer than stock????
Old Sep 4, 2011 | 06:46 AM
racin444's Avatar
Originally Posted by TheDirtman
Use whichever ones that will, when installed put your sway bar as close to level as you can. The new longer links are made for the rear and you relocate the factory rear to the front.
Are you sure? I know my Teraflex leveling kit came with front sway bar links. When I installed the leveling kit I used both spacers and the links up front and it was fine. Actually rode a lot nicer than stock too!
Old Sep 4, 2011 | 06:51 AM
2saharas's Avatar
goin with the stock ones. longer ones with the kit do go up front. i just need to bring the front down an inch due to heavy rear bumper and putting the hardtop back on....started to look like an overloaded pickup...
