Teraflex leveling kit install question (coil kit)
I'm on my phone, no internet at parents so I can't search well.
The new longer front swaybar links, the bolt is bigger than the stock one. Am I supposed to drill out the swaybar to 1/2 inch? The directions don't mention this, but I don't see any other way. Also should I replace the lower bolt? I'm assuming the teraflex link has a 1/2 inch hole, but the stock bolt is like 12mm.
Sponsoring Vendor
ORW Representative
ORW Representative
The hole being slightly smaller in the sway bar is something I heard about one other time just recently. In that case, the sway bar hole was opened up *slightly* with a dremel, the difference is pretty small apparently. I don't know why some seem to have that issue and not others. I'll be asking the guys at Tera about that the next time I talk to them.
My swaybar links that came with my Tereaflex leveling kit were 4" longer than the stock ones. I called. and asked..to no avail. Someone actually told me to switch the backs to the front and the new ones to the back. I ended up tossing them to the bottome of my tool box where they lay. I used to orig ones for a year before I put on the JKS quick disco....that are adjustable to the height you need. Sometimes I wonder about these aftermarket gadgets. Never assume they gave you the right stuff.
Sponsoring Vendor
ORW Representative
ORW Representative
On most of the Teraflex kits beyond the "leveling kits", the supplied new end links are for the rear, then you move the old rears to the front. Sounds odd, but it works out perfectly.
I thought of that, the new links were the same length as the rears. So it would have been a lot of wasted work. I ended up running a 1/2 drill bit through the holes. Much harder than it sounds. Took like 3 drill bits, a file, and lots of cursing. They really need to give people a heads up or use the proper size bolt.
I've been beaten by teraflex and aev today. Working on this jeep is an adventure. Its really my fault for assuming things would go smoothly and that the "kit" actually included all the parts and proper instructions.
I'll regroup and try again later, good thing I have another vehicle. Springs are in, jeep 1 inch higher. Aev front bumper and winch on, but I have to take it back off to get it set up right.
My TF leveling kit came with two different links. Could not figure out what so I called quadratec were I got them. Apparently they were the wrong ones so they sent me two new ones that were totally different. Mistakes happen maybe they are wrong. I do love my leveling kit thou.
Sponsoring Vendor
ORW Representative
ORW Representative
It's my opinion that almost all the manufacturers of off road products could have better instructions. I can't remember the last "good" instructions I saw.
That metal is HARD. A good quality unibit would probably work well. Working on any Jeep never, ever seems to go as planned. The older the model, the more unforeseen fun you'll have.
