Teraflex leveling kit issue
Old Oct 4, 2016 | 05:47 PM
Jeeptang's Avatar
Default Teraflex leveling kit issue
So installed the 2" front 1" puck lift on my mom's 14' Rubicon. Also had the different swaybar links.She has 33s and 17x9 xd addicts. 4.5" BS
I never drove it until today and holy body roll Batman!
What's the deal? I'm guessing it's the castor from going up, but I didn't think it would be that big of a deal with only two inches. Any recommendations..... control arm brackets?
I'd think a company like Teraflex would supply everything needed for a simple level lift.
My 3.5" xfactor on my Rubicon is like a Ferrari compared to this.
Old Oct 4, 2016 | 06:09 PM
YukonBlu's Avatar
I'm curious about this too... i'm going to be installing a 2 - 2.5" lift here soon. But i wouldn't think the castor would be affected that much, maybe a degree or 2. Maybe you just need an alignment.
Old Oct 4, 2016 | 06:20 PM
casamtb's Avatar
Shocks? When I had the TF kit on mine I noticed the body roll. Bilstein 5100s helped. I didn't notice much in the way of flightiness from castor at that height. Really we're talking 1.75 net. I eventually did put on longer arms, but that was part of the next stage build not because I felt the castor was off because of the level kit. The body roll was obtrusive and the shocks did fix it for me.
Old Oct 4, 2016 | 06:35 PM
nthinuf's Avatar
Body roll is the issue? Or flighty steering? Or something else? You need to explain the problem better to try and narrow down the 'fix'.
Before throwing parts at it, toss it on a alignment rack and see where the caster and toe are at now. Some shops won't even charge just to print the before specs.
Lots of people like the ca brackets, no reason they wouldn't work just fine on your moms jeep. Assuming that is the issue. TF makes both fixed and adj ca's that would do the job also.
If it's body roll, maybe look at a rear raised trackbar bracket?
Old Oct 5, 2016 | 01:57 AM
Jeeptang's Avatar
On these county roads the semi trucks pound down the asphalt. Driving at highway speed hitting these dips it feels like the jeep is going to tip over. Driving around corners it feels like I'm running on nearly flat tires. I actually pulled over because I thought she had a flat. I can also turn the steering wheel side to side while driving and each corner just seems to flop down. Way worse then the stock suspension prior to level
Tires are new and has been on an alignment rack. Not sure on the number.
This isn't for a future build. I'm sure she won't go any farther than this. I tried for a full kit to start with. She likes the look and that's all.
Hope that explains it a little better.
Old Oct 5, 2016 | 02:39 AM
OH9JK's Avatar
JK-Forum Ambassador
Did you already have the aftermarket wheels and tires or were they installed at the same time as your leveling kit?
Also did you install the kit or someone else?
Old Oct 5, 2016 | 05:13 AM
catahoula's Avatar
It is odd to me you are having this problem. I have been running 18/59's with rubi shocks and the full TF leveling kit. Absolutely no problems at all.
Old Oct 5, 2016 | 06:52 AM
Jeeptang's Avatar
Already had the wheels/tires on previous.
I installed everything. Haven't got a chance to look the jeep over good,but it's not good to drive.also installed my xfactor on my JK and have zero issues. So I'm pretty confident it's right. Lol
Old Oct 5, 2016 | 02:23 PM
catahoula's Avatar
Is everything torqued to spec?
Old Oct 5, 2016 | 02:45 PM
Jeeptang's Avatar
Wasn't much to torque. Bolts for sway bar links is it.
And shock bolts.
They are tight
