Teraflex lower Lengths
I was wondering about the rear Teraflex lowers. What is the length that people are running them at. Looking to get a set to try and push my rear axle back a little more. I what looking for measurement to compare to what my procomp control arms are giving me now
Thanks
Thanks
Go by the recommended length as per instructions. I believe that teraflex rear lower length is 35.25". If you go any longer you might end up hitting your passenger side rear coil with the rear trackbar. This will also alter your rear pinion angle if not you will also suffer from rear driveline vibes
