teraflex parts missing?
Just opened my 2.5" teraflex coil lift with shock adapters and it didn't include the brake line brackets. Is is necessary? Can't call teraflex cuz they're closed.
Originally Posted by Mreroe
(Post 2141068)
1. You can invest about an hour of time into a trip to home depot to pick up supplies make your own brackets. 2. You get some longer rear brakelines, which I would also recommend fronts if you are going this route since my fronts with the same kit are on the verge of being too tight. 1/2" more flex would likely be a severe issue for mine. 3. You aren't too concerned with being able to stop your jeep. Best advise, call teraflex and get the brackets you already paid for. |
take a pic of all the contents. there should only be rear drop brackets, fronts arent needed.
I'm sure if there is a missing part TF will help you out.....:thumbsup:
also, you'll be fine installing this without the brackets as long as you dont off road
Found them. They were in the newspaper stuff around the shock extensions. Thought I was in trouble. I went through that stuff over and over. Crazy how that works haha. But thanks for all the info guys.
(Post 2141702)
| All times are GMT -8. The time now is 02:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
