teraflex parts missing?
Old Mar 5, 2011 | 09:00 AM
Mreroe's Avatar
Default teraflex parts missing?
Just opened my 2.5" teraflex coil lift with shock adapters and it didn't include the brake line brackets. Is is necessary? Can't call teraflex cuz they're closed.
Old Mar 5, 2011 | 09:59 AM
Biginboca's Avatar
Yes necessary, unless..
1. You can invest about an hour of time into a trip to home depot to pick up supplies make your own brackets.
2. You get some longer rear brakelines, which I would also recommend fronts if you are going this route since my fronts with the same kit are on the verge of being too tight. 1/2" more flex would likely be a severe issue for mine.
3. You aren't too concerned with being able to stop your jeep.
Best advise, call teraflex and get the brackets you already paid for.
Old Mar 5, 2011 | 10:03 AM
wazooz2424's Avatar
take a pic of all the contents. there should only be rear drop brackets, fronts arent needed.
Old Mar 5, 2011 | 10:04 AM
07rubisteve's Avatar
I'm sure if there is a missing part TF will help you out.....
Old Mar 5, 2011 | 10:06 AM
wazooz2424's Avatar
also, you'll be fine installing this without the brackets as long as you dont off road
Old Mar 5, 2011 | 03:44 PM
Mreroe's Avatar
Found them. They were in the newspaper stuff around the shock extensions. Thought I was in trouble. I went through that stuff over and over. Crazy how that works haha. But thanks for all the info guys.
Old Mar 5, 2011 | 04:03 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Good to know, glad you found them. Remember to post pics when your done.
