TeraFlex Performance Leveling Kit, not level?
I have a 2012 JKU and just installed a TeraFlex Performance Level, it is not sitting level. The back is sitting an inch lower then the front. I have stock fenders and measured from the ground up to the bottom of the fender. The front sits at 37.5 inches and the rear at 36.5 roughly. This doesn't seem right. Could I have maybe received the wrong rear coil?? Thoughts?
I have be looking at some posts and can't seem to find measurements or issues. Some pics look like it is the same where the rear is a lower and some others they look level.
Thanks!
Thanks!
i have a 2012 jku and just installed a teraflex performance level, it is not sitting level. The back is sitting an inch lower then the front. I have stock fenders and measured from the ground up to the bottom of the fender. The front sits at 37.5 inches and the rear at 36.5 roughly. This doesn't seem right. Could i have maybe received the wrong rear coil?? Thoughts?
Thanks!
Thanks!
yeah, it threw me off at first too, because i was really looking for it. But to be honest, you dont often have the chance to see your jeep from a distance and stare at it in your everyday use. Since i put mine on, i've yet to have anyone else make a comment about it.
I'm planning to do the same lift and Dave over at Northridge says a 1" rear coil spacer would be fine. I personally need that rake because I pull a trailer. With the spacer, I'll end up with a 2" lift.
