Teraflex question??
Old May 6, 2011 | 07:27 AM
01rc51's Avatar
Default Teraflex question??
Looking to get the Travelex 2.5 for a 2011 Rubi (2door). I found the 4door lift for about $100 cheaper at one place. Will it lift the jeep to high where I need to look at replacing other parts (driveshaft and so on).
Thanks
David
Old May 6, 2011 | 07:41 AM
wayoflife's Avatar
JK-Forum Founder
if you have a manual transmission, no, you will be fine just as is. if you have an auto, so long as you run the shock extensions that come with the cheaper kit or, the teraflex shocks specifically made for that lift, you will be fine too. if you plan on running wider tires, you will want a set of 1.5" wheel spacers to help prevent rubbing but, that's about it.
Old May 6, 2011 | 07:44 AM
01rc51's Avatar
Thanks, I have an auto
Old May 6, 2011 | 07:46 AM
rdubb1031's Avatar
Different posts on here give results when they lift. Search teh 2.5" lift install and there is a super long thread with lots of measurements. You'll probably get about an extra 1/2" or so out of the 4 door kit.
