Teraflex relocation bracket
Old Oct 3, 2008 | 03:32 PM
jayrav's Avatar
Question Teraflex relocation bracket
As you all know the Teraflex 3" lift kit comes with a relocation bracket for the rear trackbar.
Here is my question: Is it better to weld the bracket into place(as recommended in the instructions) or just swap the whole thing out for a rear adj trackbar? Which option is stronger?
Thanks
Old Oct 3, 2008 | 03:36 PM
Robar's Avatar
The adjustable track bar is the better option. This allows less stress on the factory track bar bracket.
Old Oct 3, 2008 | 03:40 PM
jayrav's Avatar
Here is where it gets interesting Which trackbar then? I ask because the Teraflex rear TB uses this bracket anyways if I'm not mistaken.
Old Oct 3, 2008 | 03:42 PM
def9112's Avatar
I agree that the adjustable track bar is the better option BUT have you ever seen the Teraflex bracket?
Old Oct 3, 2008 | 03:44 PM
jayrav's Avatar
ITS A MONSTA!!! Yeah I know. So whats a guy to do
Old Oct 3, 2008 | 03:51 PM
Robar's Avatar
I believe the TF bracket attaches to the frame side of the track bar and lowers it. I was originally thinking that it attaches to the axle side and that is where the breaks seem to happen. If TF supplied a bracket and a track bar I would use both as TF makes a great quality lift and I would recemend welding the bracket, because that will increase the strength.
Old Oct 3, 2008 | 06:54 PM
jayrav's Avatar
You say use both the bracket(welded) and the trackbar. So I imagine that the aftermarket rear trackbar is stronger than stock?
Example: Teraflex rear trackbar
Old Oct 3, 2008 | 07:05 PM
Robar's Avatar
Did you purchase the rear track bar separate from the kit or was it included? The reason I ask is that I understood that your kit came with the track bar and relocation bracket and the directions stated to weld the bracket on. Generally I believe if you have an adjustable track bar you do not need the bracket.
Old Oct 3, 2008 | 07:18 PM
2k8RubiRed's Avatar
With the Terraflex trackbar they list in the instructions that you still need to use the drop bracket.
I would recommend welding the bracket. I was hit on the freeway in the rear tire. It sliced the sidewall and moved the bracket over slightly pulling the axle with it. I had to loosen everything move it over and then tighten things back up.
Old Oct 3, 2008 | 07:19 PM
jayrav's Avatar
No, my kit came only with the bracket. I'm currently using my stock rear trackbar. I was considering in purchasing a adj rear trackbar. I was under the notion that relocation brackets may cause failure. I know that I'm centered. I'm just looking to minimize roll and undue stress on related components.
