Teraflex Steering Stabilizer
Installing one tomorrow, which way does the fat end go? I have seen WOL attach it to the tire rod end, and have seen other writeups with the fat part on the axle end (per directions too)
. Does it really matter? Thanks
I have a woods SS relocation kit so I put the fat side attached to the trackbar, otherwise it hit the braket on the axle side.
It functions the same in either orientation, you just want to make sure it's not going to hit anything since the trackbar can wiggle up and down.
There have been several on here fail by rubbing the trackbar bracket. On my replacement, I was told to out the canister end toward the pass. tire per the instruction; additionally you may have to rotate the mounting point on the tie rod down for clearance on the trackbar bracket. This should agree with the instructions. You can also PM Teraflex.
