Teraflex tire carrier installed
I'm finally no longer the guy with the odd sized spare! Thanks to my teraflex hinged tire carrier I installed today. I love it! I know it's a pretty expensive piece of metal, but it works perfect for my needs and opens my options for rear bumpers without worrying about my Duratrac 315 hitching a ride in the back.
Install was fairly easy, but the two bolts on the left side of the hinge were kind of a pain... Had to use the tool provided rather than my socket wrench.
Originally Posted by joe002
How does the spare get the extra support? It looks like the bracket only supports maybe half of the tire carrier?
Not trying to high jack your thread
After seeing a few of these installed I still do not see how this actually helps. I suppose the reinforced arms going into the reinforced hinge would help some but I cant see how it would alleviate the problem all together like a bumper/tire carrier combo does.
Any mechanical engineers out there that can shed some light on this?
That's what I like about tf, they supply you with their own tool for those hard to reach spots rather than making the customer cuss and cry about figuring out a way to make it work. I liked the tool they supplied for my read spring isolators.
Dont see the need to start another thread so hope you dont mind I add to your post jksooner. I just installed mine also. I dont know about you but the instructions say to install the two outer hinge bolts first then the inside ones. I did it opposite and installed the two inner ones as I could not get them into the holes past the mount itself once I had installed the outer bolts first. Then I installed the outside one. Plus I used the smittybuilt heavy duty carrier
as I did not have the original carrier. Just had to modify it some
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=337708"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=337709"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=337710"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=337714"/>
