teraflex Trackbar bracket
Old Aug 20, 2008 | 02:12 PM
cyberbrain's Avatar
Default teraflex Trackbar bracket
Just a quick question for you guys with the Teraflex track bar bracket. I have a black diamond 3" with the crappy style relocation bracket. I know the appropriate way to fix this is with a adjustable rear trackbar. However my jeep budget for the year has run out. I do not like using this bracket at all. so just how strong is the teraflex 1954777 bracket. I am basically asking if I use this bracket will I have to worry about the axle bracket? chances are I will only go off roading once this yr. so let me know.
I have run teraflex stuff before and it was nice.
Old Aug 20, 2008 | 02:47 PM
TeraFlex's Avatar
Sponsoring Manufacturer
If you use this bracket #1954777 is mounted in 3 locations, one of them is with a u-bolt. With how this is mounted, you won't have to worry about your factory bracket coming off.
Old Aug 20, 2008 | 02:52 PM
chris15005's Avatar
I ordered this bracket SKU 1954202 In another thread it was said that i need to install bump stops with your bracket is this true? i have a RC 2.5 bb
Old Aug 20, 2008 | 03:03 PM
TeraFlex's Avatar
If your RC 2.5 BB doesn't have them on the shocks or with the kit, it wouldn't hurt. Install it and go flex in a controlled situation then make the call from there.
Old Aug 20, 2008 | 03:05 PM
chris15005's Avatar
does TF sell just the rear stops?
Old Aug 20, 2008 | 03:17 PM
TeraFlex's Avatar
Yes! We will sell any individual part.
Old Aug 20, 2008 | 03:41 PM
chris15005's Avatar
thanks I'll have to order these up when i get some xtra $$ Do you have the part # for the rear ones?
Old Aug 22, 2008 | 07:33 AM
TeraFlex's Avatar
#1954700 Rear Bump stop kit $31
Old Aug 23, 2008 | 12:58 PM
chris15005's Avatar
couldn't locate that # on the teraflexplus or tearflex site?
Old Aug 23, 2008 | 04:10 PM
Renegade's Avatar
I have that bracket and it is very nice. It is my opinion that to really do suspensions right, you should use both a relocation bracket and an adjustable bar. That allows you to dial everything in perfectly. There's nothing wrong with a relocation bracket as long as it's designed properly.
