terraflex HD d30 housing
Old Aug 30, 2014 | 01:33 PM
  #21
GunDude's Avatar
What is bent? The axle tubes. If so, I would just put in a new d30 and have tubes inserted and gussett's and truetrac.
Old Aug 30, 2014 | 01:34 PM
  #22
Jackedup's Avatar
Ok, so lets say I buy a terra d44 for 2,050.00 or a dynatrac pro rock d44 for 2,346.00 what parts would I have to buy, besides gears to be able to run either axel and how much would they cost, not including labor. I have a total of 3,200.00 for this including gears.
right now I have 3:73 gears so I wouldn't need a new carrier
Old Aug 30, 2014 | 02:24 PM
  #23
larry0071's Avatar
For me, yes, just tubes and C's are bent that I'm sure of. I have a Dana 30 lined up with sleeves and gussets already on it. I could take that and add the Detroit helical gear limited slip to it.
Old Aug 30, 2014 | 02:46 PM
  #24
TheDirtman's Avatar
For $3500 you can buy a brand new crate rubi axle with 4.10 gears and lockers including brakes. Just saying.
Old Aug 30, 2014 | 02:47 PM
  #25
nthinuf's Avatar
I didn't want to mess with another factory housing, and was on a budget, so went kinda cheap with my pr44. I don't know if it is still the same, but way back when i got mine, it came with new 'factory' balljoints included in the price of the housing, I did not upgrade to aftermarket bj's. I got it with an ARB, you would need a new open carrier or a full case locker/limited. Mine shipped with alloy inner shafts, my shop re-used the outers/hubs/brakes from my d30. I didn't itemize the individual items, so I don't actually know what the cost of the inner shafts and joints was, but I think that the full set of inner/outer/joints is around $550-600. ish?
So assuming they still include factory bj's, the difference will be carrier/locker, inner shafts, joints. Haven't priced any of it, but $500 sound about right? And it looks like the d44 truetrac is on sale for $415 at summit. Subtract 80 for the open carrier and you end up at what, $835 over the cost of the 30? (assuming I didn't miss any needed parts and came somewhat close on the costs...)
And to add to what dirtman posted.
Front factory housings. (looks like $2678 + shipping for the rubi 44. I 'think' there is the option of either 4.10 or 3.73? Plus gussets/sleeves/truss/whatever)
http://www.moparpartsdiscounted.com/...20059&fl_id=38
I imagine you will still go for the D30, just a suggestion to do some research and add all the costs for a side by side comparison.
  #26
20JK10's Avatar
Northridge sells assembled axles and you can pick your parts. Click here to get a rough idea. The only thing you would need seems to be axle shafts, unless you go with the RCV's.
Dynatrac ProRock 44 Unlimited Package (PROROCK44UNL_PKG)
Old Aug 30, 2014 | 06:09 PM
  #27
larry0071's Avatar
$3500 for an axle that will just bend? The Rubicon 44 is only better by way if ring and pinion, the rest of the axle sucks balls just like a 30, matter of fact, they share the same bendy tubes and bendy C's. You want to talk about good money spent bad, I can't think of a better example.
Old Aug 30, 2014 | 06:13 PM
  #28
TheDirtman's Avatar
You can break anything if you abuse it. If you are breaking a dana 30 housing running 32" tires it would be from driver error.
Old Aug 30, 2014 | 06:34 PM
  #29
Jackedup's Avatar
I'll have to check that out, thanks
Old Aug 30, 2014 | 07:37 PM
  #30
Invest2m4's Avatar
Well, for a few hundred dollars you can make the housing nearly as strong as a Prorock. The current D44 has beefed up axle shaft joints (started late 2013). So, you get lockers, stronger joints, more splines, etc. If you're bending a housing or C after gussets and sleeves/truss then you need some driving lessons or you run big tires on a heavy rig and need to step up to big boy axles.
And while a Tera housing is stronger than a stock housing, it is the same bendy 1/4" wall thickness, just a 1/2" more diameter. If you can bend a sleeved and gusseted stock housing, you'll bend a Tera housing.
Anyway, other than the easily improved housing, the 44 is far better than the 30.
