Terraflex Longarm Question
Old Sep 16, 2008 | 07:09 PM
tincored's Avatar
Default Terraflex Longarm Question
I put a terra flex long arm kit on my 4 door ruby, the problem is it sags on the right rear. Is that right I've only put about 400 miles on it and none have been off road. Any Help
Old Sep 16, 2008 | 07:12 PM
Robar's Avatar
How much does it sag? The JK's are known to sag a little on the right due to the fuel tank.
Old Sep 18, 2008 | 06:51 AM
tincored's Avatar
About 3/4 of an inch
Old Sep 18, 2008 | 06:52 AM
wayoflife's Avatar
JK-Forum Founder
as mentioned, the sag is totally normal on all lifts. have someone sit in the driver seat and give your jeep a look again. depending on how much fuel you have and how heavy the driver is, you will see that your jeep just about levels out.
Old Sep 18, 2008 | 07:31 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Are all your tires at the same psi?
Old Sep 18, 2008 | 07:54 AM
CLACKEY(_!_)'s Avatar
I don't have the TeraFlex LongArm kit yet.......but on my current lift I was able to level it out with coil spacers.
