is terraflex the only one?
Old Mar 2, 2014 | 07:21 AM
JK-Joey's Avatar
Default is terraflex the only one?
Im just about ready to pull the trigger on a leveling kit, and i was leaning towards the terraflex performance kit. my question is does anyone besides terraflex make a coil leveling kit? i tried looking at the evo one that was mentioned here on the forum but i couldn't find it anywhere.
Old Mar 2, 2014 | 07:27 AM
WLFMOON's Avatar
I think there are a few other companies out there that make a leveling kit, but I have had the teraflex leveling kit on two of my jks. They are easy to install and warranty is great.
Old Mar 2, 2014 | 07:33 AM
TheDirtman's Avatar
There are several companies that you can buy individual components from. The most basic leveling kit is a front 3/4" spacer from synergy for $20.
Old Mar 2, 2014 | 07:35 AM
gunbo75's Avatar
You won't go wrong with teraflex x2
Old Mar 2, 2014 | 07:36 AM
JK-Joey's Avatar
i was looking for a leveling kit that uses springs rather than spacers
Old Mar 2, 2014 | 09:45 AM
170-3tree's Avatar
Eibach makes one. There's a review on here somewhere, but I think it was decent. Other than those two, I don't know if any really.
Old Mar 2, 2014 | 09:51 AM
Dbmoorejr's Avatar
Do the tf performance kit that comes with sway bar links and you can go to 35s without issues. I had that for a while on my 13 rubi. Did have spacers on stock wheel.
Sent using smoke signals
Old Mar 2, 2014 | 12:10 PM
blue project's Avatar
You shouldn't run 35's with any leveling kit. Teraflex flex clearly states for tires up to 34"s. I know from experience that even 34"s will rub to the point where they broke my rear fender clips.
Old Mar 2, 2014 | 12:24 PM
Maertz's Avatar
Originally Posted by blue project
You shouldn't run 34's with any leveling kit. Teraflex flex clearly states for tires up to 34"s. I know from experience that even 34"s will rub to the point where they broke my rear fender clips.
sounds like improper bump stop lengths or backspacing.. you can clear larger than that if you really want to.
170-3tree's Avatar
@blue. You can trim it so you don't even need that to run 35's but yes stock fenders and no other mods will restrict abilities.
