Terrible Wobble
Old Dec 16, 2013 | 05:46 PM
cdenny's Avatar
Default Terrible Wobble
I replaced some stiff 4" procomp springs with some 4.5" synergy springs. It lifted it almost another inch. Immediately I developed a wobble when I hit a bump that is hard to keep on the road. Not sure if I would consider it death wobble but it's scary. I immediately thought track bar but after replacing the bushings no change. The ball joints are only a few months old and all the track bars are in good shape. No difference in the camber that I can tell. It's only a little more lift than what I've had for 3 years so I'm thinking next about the drag link. It's pretty sloppy but havnt had any noticeable issues at all, or maybe the steering stabilizer. Which one would you guys chase after next?
Old Dec 16, 2013 | 06:12 PM
railfan132's Avatar
Default Fix the woble
Based on my history with the same issue, I would check the drag link first, then alignment and balance. Good Luck.
Old Dec 16, 2013 | 06:16 PM
cdenny's Avatar
Thanks. Just needed a boost. I'm gonna get the drag link flip kit as well while I'm at it.
Old Dec 16, 2013 | 06:21 PM
stagedtrip's Avatar
Old Dec 17, 2013 | 08:29 AM
planman's Avatar
Forum Tech Advisor
Watch the videos and read the first posts in this thread: https://www.jk-forum.com/forums/jk-w...obbles-260145/
Old Dec 18, 2013 | 06:46 AM
Garrett J.KU's Avatar
Drang link, caster, alignment, and check every bolt in the suspension for anything loose. If its not doing it untill you hit a hole or dip in the road its not your tires. And if you cant find anthing or give up hydro assist will take it away lol <-- dont give up
Old Dec 18, 2013 | 06:52 AM
cp757's Avatar
had bad wobble turns out it was the stock trac bar flexing. Bought the Teraflex monster trac bar and northridge bolt kit. Havent had problems since.
