TF 2.5 and bilstein 5100 length ?
I know you get around 3" of actual lift with the 2.5" kit which is what i have. I am currently running the stock shocks and extensions.
Which length bilsteins should i go with 2,2.5,3,3.5
i obviously want the most articulation i can get so i want to get it right.
Also should i take the bump-stop extensions out?
if you know you're gonna get 3" of actual lift, i would get shocks that can accomodate 3" of lift
as far as your bumpstop extensions go, NO, you do not want to remove them as they exist to prevent the over compression of your coils.
