tf 2.5 coil lift
Old May 9, 2011 | 05:23 AM
girom80's Avatar
Default tf 2.5 coil lift
if i do the 2.5 in coil lift from tf do i need to change the shocks or i can use the factory ones?
Old May 9, 2011 | 05:35 AM
coachjamie's Avatar
Get the kit with the shock extensions and you can use your factory shocks
Old May 9, 2011 | 05:39 AM
Turbo's Avatar
That is true but I suggest you go ahead and get the extended shocks too if your budget allows it.
Old May 9, 2011 | 05:42 AM
wayoflife's Avatar
JK-Forum Founder
if you choose to keep your factory shocks, you will need to get the kit that comes with shock extensions as mentioned.
