TF 3" or FT 3" ?????
Old Feb 10, 2008 | 09:39 AM
GlennH's Avatar
Default TF 3" or FT 3" ?????
What lift is going to be better for daily driver with a weekend of offroad trails, rocks, sand, mud for a 2dr JK X running 35" toyos? It comes down to the Tera kit with it's qick disco's or the FT kit with the monotubes?
TeraFlex - Jeep JK Wrangler - 3" Lift Kit:
The 3” TeraFlex lift will give you increased off road articulation for moderate trails. The three inch kit is perfect for running up to 35” tires. This gives the JK a very balanced look and fills out the wheel wells.
The three inch kit includes springs, bumpstops, rear swaybar link extension, and front swaybar quick disconnects.
$763.44
Full Traction - JK Wrangler - 3 inch Economy Suspension Lift:
Our Economy 3" Lift is the simple and inexpensive way to clear larger tires up to 35x12.50*, increase ground clearance, and improve suspension articulation without major drivetrain modification. While designed to keep the cost low, this kit is complete and correct. Kit includes: Front and rear springs, front track bar bracket, rear track bar bracket, front & rear sway bar links, billet aluminum bump stop extensions, brake line extension brackets, and complete detailed instructions. System can be ordered with Full-Traction 5100 series Hydraulic shocks or M-Force Gas Monotube shocks.
Precise, comfortable street handling, combined with great off road performance make this an excellent choice for a daily driver.
* Using recommended tire widths & wheel backspacing
$694.95 w/5100 series shocks
$774.95 w/M-Force Monotubes
Old Feb 10, 2008 | 07:32 PM
cibach's Avatar
Sorry I can't give any advice but I too am looking at both suspensions and wondering the same?
Old Feb 10, 2008 | 08:55 PM
cmyjeep's Avatar
The 3” TeraFlex lift gave me 4" of lift and its still that way after 1000 miles. it rides better then stock. pic. of my jeep.
Old Feb 11, 2008 | 06:44 PM
GlennH's Avatar
seems tera dominates in the smaller lifts vs the FT is dominating the largers lifts... correct?
Old Feb 19, 2008 | 06:17 PM
ldwilbanks's Avatar
Default TF 3Inch Lift.
I installed a TF 3In last week and love it. There has only been two issues so far. (1) I had to buy an Adj. Front Track bar to locate the axle under center, it was to the driver side by about 3/4 of an inch. (2) I couldn't use the rear sway bar links that came with the kit because they were rubbing against my factory rims. I temporarily fixed by using the factory ones until I buy new rims.
Old Feb 20, 2008 | 07:28 AM
OffTopic's Avatar
I just said this same thing in another thread so I feel like I'm repeating myself but I have the FT Ultimate 3" with HD springs and 35" Toyos on my 2DR and it is SWEET! I am sitting about an inch taller than guys with bigger lifts, and I absolutely love the way it handles on and off road. That's the Ultimate, not the Economy, so I'm not sure how much of a difference in ride there would be, but I've had absolutely no problems with it, and when a woman tells you she loves the way it rides and handles (on and off road), you know it's got to be good.
