TF BB2.5 trackbar bracket
Old Mar 29, 2008 | 07:41 PM
  #41
Sparky99's Avatar
Originally Posted by sjbissett
The new bolt also provides extra support to the stock bracket. It is up to you but it seems like it is worth the time/effort to drill the hole and install the new bolt
I think it's worth it to do it. I think there could be enough pressure on the bracket to cause it to rotate some. 3/8" drill bit and it went right through. I just put the relocation bracket in place, put the big bolt through to hold it there and drilled right through the small hole so I didn't have to worry about drilling in the wrong place. I installed mine while putting the lift on and did the drilling while the trackbar was disconnected, but I would think you could do it without disconnecting it again. I would just make sure the TF bracket is flush inside the stock bracket.
It's a nice piece of mind for me.
Old Apr 7, 2008 | 10:46 AM
  #42
xldme's Avatar
Anyone know where I can get the teralfex relocation bracket. I called 4wd and quadratrac. Both are telling me it will take another 3 weeks before they get their supply. That's three weeks on top of the three weeks that I've already been waiting for from quadratrac.
Old Apr 7, 2008 | 10:48 AM
  #43
TeraFlex's Avatar
Sponsoring Manufacturer
Northridge has lots.
Old Apr 7, 2008 | 10:50 AM
  #44
xldme's Avatar
Thx. I will give them a call.
Old Apr 7, 2008 | 11:01 AM
  #45
xldme's Avatar
TeraFlex,
Thanks, you guys are awesome. I just got off the phone with NorthRidge and the are shipping one out to me today.
Old Apr 11, 2008 | 03:18 PM
  #46
jkjeep'n's Avatar
I got my bracket today that was left out of my kit. No charge. Is their a consensus at this point about the extra bolt. TF says no drilling required with the bracket. I know some have added it and some havent.
Is this a pretty easy install after the fact? Just unbolt the track bar from the factory mount and add the re-location bracket? Anything special I need to know?
Old Apr 13, 2008 | 05:53 PM
  #47
jkjeep'n's Avatar
Well, no response, and I had to wait untill today as we went out of town for spring break and then soccer for the weekend but I installed the bracket today with no problems. Haven't had a chance to check it out on the highway above 70 mph where I seem to get the wandering issue but I'll get to check it out tomorrow.
Old Apr 13, 2008 | 06:51 PM
  #48
SASQUATCH's Avatar
Got my kit used so didn't even know about this stupid bracket and now I realize that I just need this Vs an adjustable rear trackbar to line the axle back over a 1/2". I'm assuming that's what this bracket does with my 2.5" TFBB...right?
Old Apr 13, 2008 | 08:10 PM
  #49
texasKA's Avatar
so do you have to drill a hole in order to install the missing bolt?
Old Apr 14, 2008 | 06:11 AM
  #50
element981's Avatar
Mine came with the bolt, but yes you do have to drill and you may have to file the factory hole a little. I did because the bracket holes did not line up with factory holes (not by much less than 1/8") so the track bar bolt would not go through without filing.
