TF front sway bar disco bolt
Old Mar 1, 2010 | 06:14 PM
leonard08jk's Avatar
Default TF front sway bar disco bolt
Am i missing something here .In the directions it says to use the bolt to put the new one back together . what bolt do i use to hook it back to the sway bar .I use the bolt with the pin on the axle but what one for the sway bar.
Old Mar 2, 2010 | 02:29 AM
Mark Doiron's Avatar
You might refer to my write-up. I did the install slightly differently. You need to be careful about which bolts you use where because there are two on each side that are almost identical--but aren't. The write-up goes into detail ...
Teraflex Quick Disconnect Install
