TF Hinge and Mount Question
Old Jan 23, 2013 | 12:17 PM
Gammo12's Avatar
Default TF Hinge and Mount Question
Anyone else using the TF hinge and mount have the tire rubbing/touching the hinge? I am using a stock wheel, so I understand that it will sit closer to the hinge, but I did not think it would be up against the hinge.
Old Jan 23, 2013 | 12:20 PM
banx's Avatar
Mine is close but no rubbing. I have a 4.75 backspaced wheel though with room to spare (pun intended) for adjustment out further. If you are adjusted all the way out, you may look at picking up a cheap wheel spacer.
Old Jan 23, 2013 | 12:34 PM
Gammo12's Avatar
Here is what it looks like:
Name:	tire tf 3.jpg
Name:	tire tf 1.jpg
Old Jan 23, 2013 | 12:38 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Nothing wrong with having the tire against the hinge portion, that will help keep it from jiggling around.
Old Jan 23, 2013 | 12:43 PM
Gammo12's Avatar
Thank you. I appreciate your input. Just seemed a little too tight in there. Is there a point where it is too tight and can be a concern?
Old Jan 23, 2013 | 12:51 PM
TeraFlex's Avatar
I would say cranking the lug nuts down and having the studs pull out would be too tight. Otherwise you'll be fine, it's better to have that tire snug against it than jiggly.
Old Jan 23, 2013 | 01:29 PM
Gammo12's Avatar
Ok. Thank you. So you're saying if the lug nuts are too tight then that would put a lot of stress on the studs?
Old Jan 23, 2013 | 01:50 PM
TeraFlex's Avatar
If you have a stock carrier yes, if you have a TeraFlex one I wouldn't even worry.
Old Jan 23, 2013 | 03:15 PM
Gammo12's Avatar
I've got the hinge and mount. I'll throw the tire back on and I'll let you know if there are any other issues that come up. Thank you!
Old Jan 23, 2013 | 03:18 PM
Ryan0260's Avatar
Throw a spacer on it. Problem solved
