TF Leveling kit issue
Old Mar 30, 2010 | 05:52 PM
CLOTAGAMES's Avatar
Default TF Leveling kit issue
Have had the TF leveling kit on for about 1000 miles. Have been hearing a noise when I hit a bump from the rear left shock area. Crawled underneath tonight and see my MBRP exhaust pipe is hitting my rear stock spring. Looked up and saw the rear spring is not seated in the center of the upper spring mount? Any ideas-running stock springs and shocks with TF leveling kit.
Old Mar 30, 2010 | 05:57 PM
nthinuf's Avatar
Installer error.
Or you somehow over-extended while offroad and it unseated. If you are using stock shocks, not sure how you could have done it. Usually only hear of that with longer shocks and no limiting straps
Old Mar 30, 2010 | 06:29 PM
JKRINGO's Avatar
My guess would also be that it has to do with the installation. I have this lift and I had to drop the whole rear axle at the same time in order to remove the springs. When raising the axle back up I had to check two or three times to make sure everything was lined up correctly.Sorry to say, but sounds like you may have to re-do that rear spring.
Old Mar 31, 2010 | 06:06 PM
CLOTAGAMES's Avatar
Default Error
Install error was right on. I had to hold the teraflex spacers up in place while I jacked the back axle up to put pressure on then to get them to seat. Thanks guys. Did learn even with the shocks and rear links and brake line unbolted-I had to take the park brake cable loose from the holder up under the tub to get enough flex to get the springs and spacers back out-I had a couple of inches that way.
Old Mar 31, 2010 | 06:11 PM
JKRINGO's Avatar
Glad to see you got it taken care of.
