TF Leveling Kit - Lost bolts, nuts, and metal sleeve for swing arm links - size?
I was wheeling last weekend and lost both the top bolts that hook the swing arm to the links along with the metal sleeves inside the swing arm link heads. Does anyone know the size of the bolts and sleeves. Need to get the front hooked back up so the wife can take the kid to the beach. Thanks.
Replacement Sway Bar Links aren't too terribly expensive if you went that route but you might want to PM the Teraflex Rep on here or even call Teraflex directly and see if they can cut you a deal on just the attachment hardware and sleeves. I'm sure you could find a suitable bolt at a auto parts store but the sleeves might be hard to come by in terms of them fitting properly and not chewing up your joints. I'd recommend calling up Teraflex and seeing what they can do for you.
Sponsoring Manufacturer
4-7/16" washers
2- Nut 12mm x 1.75 P Stover Lock Zinc Plated
2-Bolt 12mm x 1.75 P x 55mm Long Zinc Plated Hex
I have some sleeves that I can send.
Thank you. I will let you know on the sleeves. I think I found some sleeves that will work. I will be putting it back together in the morning. I haven't determined if I bent anything yet.
Thanks Teraflex
Sleeves I found worked out. Thanks for the info and bolt size. Rubber inside of driver side swing arm link is pretty chewed up. Lower bracket bent, think I can hammer that back. I am going to run it for a while and keep an eye on it, but will probably end up ordering a quick disconnect kit - only disco's if swing arm links hold up or full set if they look like they are failing also.
