TF spring lift and rake question
Old Feb 20, 2011 | 10:27 PM
troyboy's Avatar
Default TF spring lift and rake question
Hi, will the TF 2.5" spring lift correct the rake? Do any other spring lifts correct the rake? I have stock bumpers so no extra weight.
Old Feb 20, 2011 | 10:30 PM
stlfan06's Avatar
Originally Posted by troyboy
Hi, will the TF 2.5" spring lift correct the rake? I have stock bumpers so no extra weight.
Yes.
Yes.
Old Feb 21, 2011 | 03:23 AM
Biginboca's Avatar
I'll second that. The TF 2.5" coil kit left no noticeable rake when installed on my Unlimited Rubicon.
Old Feb 21, 2011 | 03:46 AM
jkerr's Avatar
The TF lifts will correct the Rake; however, if you add a winch or something heavy up front that isn't balanced out in the rear you will have a rake. Most folks add a 1/2" spacer up front to mitigate this issue.
Old Feb 21, 2011 | 06:24 AM
Kalamari's Avatar
I like the rake. I have the lift kit (not installed yet) and I plan on putting spacers in the back. I hate when I put anything a little heavy in the back and the ass end sags. I've got 4 bags of water softener in it right now and the back is way lower than the front. Drives me crazy! Just imagine what a big spare tire would do.
Old Feb 21, 2011 | 06:37 AM
jkerr's Avatar
I'm with you on the rake/no rake debate. I pull a trailer and my headlights point to the sky if I don't have some rake in the rear. On my JK; however, even with a 3" lift up front and an 1/2" spacer in front & rear I still end up having about 1/4" rake in the front. My rig is a heavy beast up front. I have an expedition one bumper, Warn winch, RIPP supercharger and Dual Batteries. Towing still brings me down to nose high, so I compensate by using air-bags pumped up to 35 PSI in the rear. This keeps me about neutral to sometimes slightly tail low. Putting a 1" spacer in the rear would be too much for me for normal day-to-day driving. I wish they had .75" rear spacers.
