TF TB Relocation Bracket?
Old Jan 29, 2009 | 04:30 PM
sully151's Avatar
Default TF TB Relocation Bracket?
I am finishing my lift install and am trying to get my Track Bar Relocation Bracket on.
There are 3 holes on top to bolt the track bar to. I have seen Pictures with it bolted to the top, but the bolt seems like it will hit against the coil. Any thoughts?
BTW it is a TF 3" lift
Old Jan 29, 2009 | 06:55 PM
Gokracer1's Avatar
When I had the TF bracket I set it to the center hole. But I a lot of people run it in the upper. Try both and test it out. Do you have adjustable control arms? Did you set pinion angle also?
Old Jan 29, 2009 | 07:21 PM
sully151's Avatar
Thanks, I set it in the middle. We'll see how it goes.
No control arms yet. One step at a time.
Old Jan 29, 2009 | 08:04 PM
Gokracer1's Avatar
That may also be why the bolt might hit the spring not having arms. When you set your pinion angle it will twist the axle back getting the bracket farther from the spring.
TeraFlex's Avatar
Sponsoring Manufacturer
Middle or bottom is a good place to start.
