Thicker rear sway?
The Anti Rock was about the same as stock. I didn't notice enough of a difference to matter as it pertains to roll. I have a 4" lift and still can take the corners.
I just installed the Full Traction HD rear sway bar , primarily because I tow my trailer. It feels much more solid in the back end on road and there is definately less body roll. Unfortunately I haven't been able to take it offroad and when I do I will only have one trip to compare it to while offroad. I called Full Traction prior ot ordering it and they told me that it would not hamper performance offroad.
Hopefully this helps.
I'd factor quick disconnects into the equation if you go stiffer than stock.
A heavier sway bar will not limit articulation compared to the stock sway bar, the axle will still be able to droop or raise as much as the suspension geometry allows. What a heavier sway bar will do is influence the likelihood of articulation. Having a heavy rear with a soft or disconnected front is going to force the front end to do more work. Generally this will mean that the rear won't articulate as much, at least not until it is under heavy load. So basically, a heavier rear sway bar will indirectly cause less articulation, but the sway bar itself will not be limiting it. Make sense?
Some has to do with how long the arms are from the sway bar to the links. A heaver bar doesn't automatically mean stiffer. It depends on the leverage created by the arms to twist the bar. This is why some sway bar systems offer multiple holes to set desired stiffness.
Shorter the arms=less twist.
This is getting to technical.
