Third brake light advice
Old Mar 20, 2010 | 04:52 PM
Marshall's Avatar
Default Third brake light advice
Im replacing my stock bumper with a bumper/tire carrier combo...it does not come with provisions or suggestions for the 3rd light
for those who have added a light, how/what did you do? Pics/suggestions please..
FYI, its the Rancho carrier, and Ill be running the factory moab on it with a 35
Thanks for your assistance!
Bryan
Old Mar 20, 2010 | 05:06 PM
pettym's Avatar
Default Teraflex 3rd light
TF has a decent solution. It should still work with your carrier but it will not be on the swing out, rather still on the jk tailgate. That's probably how I am going to go once I get my rear bumpr
http://www.teraflex.biz/products/jk-...n-bracket.html
Old Mar 20, 2010 | 05:15 PM
spinlock's Avatar
If you are using the stock wheels or ones that have wide enough openings in the wheel there are a couple solutions that go behind the spare rim.
One the simplest is a $10 LED light on the rear glass.
If you run a SEARCH you will find endless solutions.
Old Mar 20, 2010 | 06:05 PM
Marshall's Avatar
I have searched, and have seen the ones from different vendors...really leaning towards an LED behind the rim...was just looking for finished product pics...etc...
tks
Old Mar 20, 2010 | 06:13 PM
Fathom's Avatar
I bought the 3rd light kit from AEV (CHMSL). It comes with a great bracket that bolts in behind the wheel (using the studs that hold the wheel to the tire carrier).
That is it's strong point, the weak point is the actual light. Three little (fairly dim) LED's make up the light. I went to a Auto Zone and picked up an aux. brake/tail light. Here's the pick of the lights (small one is the AEV).
Old Mar 20, 2010 | 06:20 PM
phljeeper's Avatar
I just cut the original off the stock carrier and bent a bracket to hold it. Here are some pictures:
Old Mar 20, 2010 | 06:46 PM
JPTwinz's Avatar
Move you license plate to the spare like I did using a Rock Hard 4x4 relocation bracket then you can use a ORO Plate Lite. It has an LED 3rd brakelight plus a LED (looks like HID) license plate light. All for around $80 through 4wd.com, 4WheelParts, Quadratec or Northridge.
Install thread including wiring codes...https://www.jk-forum.com/forums/jk-write-ups-39/rock-hard-license-plate-relocation-bracket-oro-led-platelite-install-xrc-bumper-90672/
Running light only....
Just the plate light illuminated...
The LED brake light plus the plate light....
Brake light only....
Everything illuminated....
And some daylight shots...
Old Mar 20, 2010 | 08:08 PM
MrMoJo's Avatar
Check your state law but I'm guesing it's not required. Thinking of cutiing mine off.
Old Mar 21, 2010 | 07:52 AM
Fathom's Avatar
Heres a pic of the Auto Zone aux light in action:
Old Mar 21, 2010 | 11:35 AM
Marshall's Avatar
That is exactly what I was looking for! Thanks to all that responded!
