Third Brake Light Advice
Old Jul 10, 2013 | 07:15 PM
Monty1107's Avatar
Default Third Brake Light Advice
Anyone running the AEV CHMSL 3rd brake light or Delta lug nut brake lights? if so which one is brighter. Positives and negatives. Thanks
Old Jul 11, 2013 | 04:15 AM
hooper's Avatar
For the money I think the Delta spare tire is the way to go. It is plenty bright enough.
Old Jul 11, 2013 | 05:11 AM
Firelyle's Avatar
I've got the Delta's. No problems. Just unplug when you remove your spare and you're set.
Old Jul 11, 2013 | 06:03 AM
woodyvw9's Avatar
Veteran: Coast Guard
X3 on the Delta's. It is a quick and easy install.
Old Jul 11, 2013 | 06:16 AM
evoviii2jk's Avatar
I have the AEV and it's plenty bright, but since I'm running fuel wheels I had to flip it around so that it sits inside the wheel vs sticking out. Just a heads up if you aren't running aev or stock rims
Old Jul 12, 2013 | 10:27 AM
Monty1107's Avatar
Thanks guys. Delta it is!
