To those running FT Ultimate 3" ??
Old Sep 12, 2007 | 05:59 AM
1BADJK's Avatar
Default To those running FT Ultimate 3" ??
For all of you running the Full Traction Ultimate lift.. Have you guys noticed any clanking with the Heim Joints yet.. ?? I know with my TJ and the Skyjacker Skyking 8" coil over lift after about 6 months the Heim Joints started clanking like mad... Drove me crazy.... Just courious if the technology has caught up yet.. Thanks..
Old Sep 12, 2007 | 06:17 AM
wayoflife's Avatar
JK-Forum Founder
Well, I've had my Full Traction 3" Ultimate Lift on my JK since March and have put on over 10,000 miles on it and no clanking so far
Old Apr 18, 2008 | 07:32 PM
codcape's Avatar
Default Full Traction Clanking
I just had the 3 Inch Full Traction Ultimate Lift Installed I have about 1500 miles on my 2008 Rubicon Unlimited and it has developed a Clanking Noise. We just Re Torqued everything and I still have it! I am VERY FRUSTRATED!! Any suggestions would be GREATLY APPRECIATED. Thank You, Rick
Old Apr 18, 2008 | 07:37 PM
Piginajeep's Avatar
If its a clank, it could be your sway bar links, they'll make some noise. but its probley your track bars.
You need to greese your track bar bushings with white lithium greese. Dont be shy, soak them down!, dont torque. Just tighten them as much as you can turn them...
then give one more turn after that.
Problem solved
Old Apr 18, 2008 | 09:23 PM
Rebel Heart's Avatar
I ordered the grease from Dave at Northridge, so hopefully if I keep it greased at regular intervals, I should be ok?
Old Apr 18, 2008 | 09:32 PM
Piginajeep's Avatar
yep, You'll be good!
