for those of you using the Flashpaq in a 2007-2010
Old Oct 10, 2013 | 11:17 AM
8000ft's Avatar
Default for those of you using the Flashpaq in a 2007-2010
As a new user to this device I am wondering what tunes you have been using.
I have a call into Ron @ Superchips about being able to view the PID's because under the advanced settings they are apparently missing.....or I am just not looking in the correct place.
I went to the additional features then to the advanced functions and I had 4 options. Quick Tire Size, Axle Lock, Idle Setpoint, and Tire Pressure. Am I missing something??
Old Oct 10, 2013 | 12:16 PM
Neral22's Avatar
So far i have run 87 and got 13.33 mpg ran towing, more power and 13.5 mpg, trying the duel saver now, big power loss, will see what it gets me. I run the settings for an entire tank, all city driving same routes/distance. I have 33" duratracs on 15"
Dont do advanced, just set tires etc through additional, then quick tune for options.
Old Oct 10, 2013 | 12:18 PM
backwoodjk's Avatar
I have only seen the four options you have listed under advanced settings, but I have only had mine a couple weeks and could be missing something as well.
Old Oct 10, 2013 | 01:08 PM
nthinuf's Avatar
Tow with 87 gas worked best for me.
BUT - It doesn't really matter which tunes we are using. You need to try a few and see what works best for you - in your location, with your build, and your driving style, and your performance needs.
Old Oct 10, 2013 | 01:47 PM
Neral22's Avatar
Under quick tunes you should see: 87, 89, 92(or93), towing, crawling, ms (i think, mx? milage saver)
Old Oct 10, 2013 | 02:12 PM
Ryan0260's Avatar
X2 on this, but tow is probably my favorite.
Old Oct 14, 2013 | 06:58 AM
8000ft's Avatar
OK, Why tow?? I am RARELY deep in the skinny, and I live in a small town with one main road so merging into trafic is a non-issue. Has tow given you a bit better low-mid torque?
Old Oct 14, 2013 | 08:32 AM
Joe_B's Avatar
I run the 87 tune with 89 gas. I like it the best. It runs smoother with 89 fuel then it did with 87 fuel.
Old Oct 15, 2013 | 07:57 AM
djlarroc's Avatar
I initially ran the 91 tune.. It felt better compared to stock of course, but after some reading, I found most guys run the tow, for the better shift points and better lower rpm torque.
I can barely tell a difference to be honest, but i'm sure it probably is a bit better. The 91/93 gives you an extra 2HP or so, but near redline. I RARELY go over 4K RPM, so I have mine set to tow.
