Thoughts on automatic lockers...
Old Nov 14, 2010 | 01:01 PM
Foosh's Avatar
Default Thoughts on automatic lockers...
I'm going to add lockers to my sahara when I have it regeared to 5.13. I'd like to have e-lockers with the OEM control pod. Are they better or worse than air lockers?
Old Nov 14, 2010 | 01:13 PM
nthinuf's Avatar
Automatic lockers, or Selectables?
E-lockers and air lockers are selectables...
Read the posts by Dynatrac in this one
https://www.jk-forum.com/forums/show...28-best-locker
Old Nov 14, 2010 | 01:19 PM
Foosh's Avatar
Yeah I guess that's what I meant. Thanks!
Old Nov 14, 2010 | 01:27 PM
nthinuf's Avatar
For selectables, ARB is the top of the line. The one that all others are compared against.
From the info in that thread, the D30 E-Locker is a very good option. The negative is that the D44 E-Locker isn't as good as the d30 version. (4 pin for the d30, 3 pin for the d44) So if you go with the front elocker, you are left with a choice of what to use in back. A 3pin elocker or a 4 pin arb, which you would have to get a compressor for.
Old Nov 14, 2010 | 02:03 PM
Foosh's Avatar
Or I could just put on front and rear rubi axles with the OEM lockers already in them, right?
Old Nov 14, 2010 | 02:14 PM
nthinuf's Avatar
If you can find some cheap take-offs, sure. If you are buying new, you would be better off just going to a ProRock front.
