Thoughts on Metalcloak suspensions?
O||||||O
I am not a fan of the spacers. Regardless, do one or the other, but no need for both.
It's not lift height, but how much droop there is (max extended length of shocks). With a 2012+, if doesn't take much before your driveshaft will hit the exhaust crossover when the axle is drooped. That said, in reality, both wheels are usually never extended at the same time. I ran a 1310 shaft with the Game Changer plus 6pak shocks and left the exhaust. Yeah, if both shocks were extended, there was contact with the exhaust. Reality, I never had a contact issue offroad. I am not a fan of the spacers. Regardless, do one or the other, but no need for both.
Even in extreme rock crawling, usually one tire is stuffed. Anyway, you need to do one of the two options, but I don't think both are needed.
One note on the driveshaft - the issue you are referring to is clearance with the exhaust. You can also run into a problem with the joint at the tcase end of the shaft. Kinda the same deal, there is no set lift height number where you will or will not have an issue, it's the overall height, whether you disconnect, shock length, etc, etc.
Just something to be aware of, and another item to add to the list of things to check as part of normal maintenance.
One note on the driveshaft - the issue you are referring to is clearance with the exhaust. You can also run into a problem with the joint at the tcase end of the shaft. Kinda the same deal, there is no set lift height number where you will or will not have an issue, it's the overall height, whether you disconnect, shock length, etc, etc. Just something to be aware of, and another item to add to the list of things to check as part of normal maintenance.
O||||||O
