Thread Locker on Spyderlocks?
Old Apr 22, 2014 | 02:33 PM
GreatWhite JK's Avatar
I am getting ready to mount up my spyder locks and they recommend that you use thread lock and i noticed that the threads are pressed in so i dont know if I would want to because of the chance of taking the wheel apart and to have the threads just pin while I... So i researched and watched a video of Mel put together an atx slab and he said to never use Thread lock... So what did you do on your spyderlocks/slabs? Thanks Mike
Old Apr 22, 2014 | 09:35 PM
JKZinger's Avatar
I don't use anything. Have been running them for 2 years without them coming loose once they are torqued properly.
Old Apr 22, 2014 | 11:49 PM
jeremyreed's Avatar
Used it on mine....use it on the oem studs holding spacer on.not spacer studs holding wheel on.they come with it for a reason.
Sent from my SM-N900V using Tapatalk
Old Apr 23, 2014 | 01:08 AM
OH9JK's Avatar
JK-Forum Ambassador
I believe the OP is referring to Spyderlock bead lock wheels and not the SpiderTrax spacer/adapters
Spyderlock does recommend using BLUE loctite and torquing to 25 ft lbs.
However the general consensus in the bead lock community is to use a little anti-seize and just keep a check on them. The dissimilar metals tend to corrode and can be difficult to remove or worse seize up and break off.
Old Apr 23, 2014 | 02:53 AM
Originally Posted by OH9JK
I believe the OP is referring to Spyderlock bead lock wheels and not the SpiderTrax spacer/adapters Spyderlock does recommend using BLUE loctite and torquing to 25 ft lbs. However the general consensus in the bead lock community is to use a little anti-seize and just keep a check on them. The dissimilar metals tend to corrode and can be difficult to remove or worse seize up and break off.
ya i was actually going to use anti-seize if i did use thread lock because that what I used on my old champions...
Old Apr 23, 2014 | 07:17 AM
09GRNJK's Avatar
A little bit of anti-sieze and I would call it a day. For me, that's a hard pass on thread locker for rings.
