"Throaty-est" Muffler?
Old Feb 2, 2009 | 05:07 PM
  #21
DuDz40VT's Avatar
i think i'm going to go with the flowmaster super 40, which is the correct one?
http://www.flowmastermufflers.com/40_super.html
Old Feb 2, 2009 | 05:10 PM
  #22
DuDz40VT's Avatar
WOah wait a second, what is the super 44??? it says it's "the most aggressive, deepest sounding, highest performing four inch case street muffler we’ve ever built!" would that be better than the 40?
Old Feb 2, 2009 | 05:17 PM
  #23
DeluxeJK's Avatar
i was lookin at that super 44 last night and was thinking the same thing. I dont know if i should get the super 40 or try out the 44?? either way, my experience with flowmaster def makes me wanna take that route
Old Feb 2, 2009 | 05:21 PM
  #24
RedneckJeep's Avatar
Originally Posted by nikbass
This is doable Mythbusters proved it.
I'm also concerned with top off volume, I guess I'll check into the 50, anything to make my buddy's TJ look smaller.
THe arguement wasn't against a turd's polishability. It was merely stating that no matter how shiny, all you got is still a turd.
Old Feb 2, 2009 | 05:43 PM
  #25
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Yeah but a turd that performs better and is more eye appealing is more my style!
Old Feb 2, 2009 | 06:38 PM
  #26
hyatt147's Avatar
when i talked to my local shop they said the 44 is not durable and will not last, and really isn't that great of a product for a daily use car....They said they would do a super 40 and would recommend nothing else
Old Feb 2, 2009 | 06:39 PM
  #27
JackMac4's Avatar
Originally Posted by hyatt147
SO where are all u guys getting your Flowmaster setups done? Just a local muffler shop?
Just local muffler shop. In and out in about 30 minutes and $130 later. The super 40 is black as well, but after a year the black paint on it is about half off..just need to hit it with some more high temp paint. The hardest part was they had to weld on a new hanger - since the muffler is much smaller than the stock one, so the stock hanger is a bit far away. So weld that on, and weld the muffler up and you're done. Could easily be done yourself if you have a welder.
I don't think you'll see that big of a different - not with this turd v6 pushing it.
Old Feb 2, 2009 | 06:44 PM
  #28
DuDz40VT's Avatar
ok great, so which super 40 is the right correct part # for the jk?
and to everyone with an aftermarket muffler did y'all just put a tip on the end or? if so which/what one did you use?
Old Feb 2, 2009 | 07:27 PM
  #29
Crazyboattower's Avatar
I used a magnaflow 6" universal round muffler. I Like the sound and it's got a pretty good deep throat to it. I had the local muffler shop do it for $150 including the muffler. I should have done it myself, it's so easy.
I wanted the muffler moved under the drivers seat area and I had them reuse the stock pipe past the axle then added a piece to the end. I would have cut the pipe under the drivers seat where I wanted the muffler to start, clamped it, cut out the length of the muffler out of the stock pipe, then clamped it to the muffler and you're done. I had the muffler shop run the exhaust out the back of the jeep, but I kept bumping into with my shorts so I cut it off past the rear axle and I love it.
Here's the muffler I used http://www.magnaflow.com/02product/universalsatinxl.asp
Old Feb 2, 2009 | 07:45 PM
  #30
wizzo's Avatar
how about gibson that sounds good to me
