Throwing in the spare.
Old Mar 10, 2011 | 02:33 PM
Verdulken's Avatar
Originally Posted by ronjenx
Each tire is off the ground 20% of the time, so they last longer.
If you intend to sell the spare when the others wear out, the economy of the 5 tire rotation may be compromised.
I don't know, as I haven't done the math for that..
Thx , I still need to check if the Toyos MT's are direccional.
Old Mar 13, 2011 | 03:37 PM
SWRUBI's Avatar
Originally Posted by Verdulken
This is interesting. I never done it like this, some questions:
- What is the advantage besides this explanation :
Five tire rotation results in equally distributed use that will help maintain equivalent tread depths on all five tires throughout their life. When applied to many four-wheel drive and all-wheel drive vehicles, this is required to prevent driveline damage if a flat tire forces a new spare to be put into service with partially worn tires on the other three wheel positions.
- How does 5 tire rotation increase the live of your tires ?
- I have Toyos, can I do this or are they Directional ?
My thinking was that I can kill my 4 tires and hopefully never use the spare , this way I can get some $$ by selling it as almost new if I buy a new brand or upgrade to bigger ones. Maybe it was just my cheap-thinking kicking in
Thx
Use the spare. No use just seeing it hang from your tire carrier forever. I wouldn't consider selling it even if it were never used. Tires these days have a DOT rating on them. New tires basically 'expire' 6 years after they are manufactured. The code on the tire is a four number code such as 2611 which notes 26th week of 2011 manufacture date and it's considered good for 6 years from that date. Too much liability selling it if it has exceeded it's 6 year theoretical lifespan.
Old Mar 13, 2011 | 03:40 PM
SWRUBI's Avatar
This is the pattern I use.
Put the new one on the right rear. This will keep it on the Jeep the longest time before it gets to the spare position.
Beware of the new tire's size compared to the used ones. If it's more than a few thirty seconds of an inch bigger, it may give you ESP problems.
Thanks for posting this. Boring afternoon so I decided to rotate the tires.
Where are you fellows jacking your rigs when doing this? I used the rear pumpkin and the front lower control arm brackets as lifing points.
