tie psi for km2s
depends on you rim setup and wieght of your rig? somewere between 25 and 32 should be about right. i run mine at 28 and i have a heavy rig and 9.5 wide rims on 17.
do the chalk test and you will find the best for you.
chalk test is were you rub chalk on your tread the whole width of the tire and a inches the lenght of the tire. With the tire set at what pressure you might think and drive on flat and smooth road stop after a small distance (20 yards or less) check the chalk. and adjust accordingly. Chalk gone in the center too much pressure and vise versa. chalk wear should be even from one side to the other.
Had an inch on the ground when we got up and it's been snowing all day.
Beel
